PC recommendation for AutoCad 2021
bclantonGDMQM
Observer Observer
bclantonGDMQM
Observer
Observer
I am contracted I.T. for a custom furniture company and they would like a recommendation for a fast performing PC for AutoCad 2021.   Company I work for is a reseller of Dell products so I am going to quote a Dell.  With AutoDesk only being a single threaded application, I don't believe I need to quote them a $2000 machine.
Can anyone give any recommendations?
pendean
Community Legend
Community Legend
Dell Support know how to configure for AutoCAD: you can use the system requirements' RECOMMENDED entries as the average for an average user too https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
>>>...I don't believe I need to quote them a $2000 machine...<<<
You need to know for sure what size files and how many they like open all day long before making that judgement call on your own in a vacuum.
j.palmeL29YX
That depends on what they want to do with AutoCAD. The Render command e. g. uses all kernels (multi threaded).
Jürgen Palme
bclantonGDMQM
Observer
Observer
Here is a bit more info regarding their setup:
" The average size is 15MB-50MB They are 99% of the CAD files is 3D entities and Paperspace Layouts.
We rarely use the Render command so I wouldn’t even consider it in this build.
The program also connects to the SQL database "Microvellum Data" and is constantly writing and accessing data. Think of it as a symbiotic relationship between the database and CAD file. Every project that exists in the database and has a CAD file associated with it. As things are drawn in the cad file, information is modified in the database. That's why I brought the network speed/connection as an issue in this."
pendean
Community Legend
Community Legend
@bclantonGDMQM You will start with a Dell Precision "workstation" desktop (or Laptop) i9 or i7 or i5 at the highest clock speed then, use the "recommended" listings from the system requirements as the MINIMUM for this client of yours
http://precisionworkstations.com/recs/AutodeskAutoCAD.pdf
Good thing you checked with the client.
bclantonGDMQM
Observer
Observer
Thank, this gives me a place to start.
