Path Array Change Alignment based on polyline vertex
Message 1 of 1
In Autocad2020 LT, is it possible to change the path array alignment settings based on the vertex of a polyline, or even distance along the path?
For instance, I would like to on "Align items" on arcs, but have straights set to "Do not align". In the attached example options 1 and 2 are what seems to be achievable, but I would like to make option 3.
If I can't change alignment along a path array, is it possible to link two separate path arrays, such that they share the same measured spacing, and the start point of the 2nd path array is dictated by the last object in the previous?
Replies (0)
