Pat file troubles
Pat file troubles
DJB266
Message 1 of 17
Pat file troubles
DJB266
A couple years ago, I edited the acad.pat file to include some ceiling tile sizes (imperial) because I use them a lot
*CEILING 2x4, CEILING TILE
0, 0,0, 0,24
90, 0,0, 0,48
*CEILING 2x2, CEILING TILE
0, 0,0, 0,24
90, 0,0, 0,24
Works like a charm.  They show up as one of the "predefined" patterns whenever I go to hatch, so I don't even have to go to the "custom" tab.
So here's the issue...  I just added another pattern to the acad.pat file for a tile size I use a lot.  I literally copied the text from the ceiling tile and edited for different dimensions.  Should have been easy.
*TILE 18X72, 18x72 PANELS
0, 0,0, 0,18
90, 0,0, 0,72
Acad does NOT see this.  Not a pathing issue.  It's looking right where the file is.  I've checked multiple times.  I've restarted the software.  Restarted the computer.  All to no avail.
I've even tried separating the file into it's own pat file.  Can't find that file either.
Help!
I'm at a loss as to what I'm doing wrong.
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
Did you edit the correct ACAD.PAT file? How do you know it is, how and where did you find it? The most common problem for what you wrote @DJB266
Also... Is there a blank line above and below this newly added pattern to your main ACAD.PAT file? Needed.
And by chance have you restarted your AutoCAD session since the addition?
Message 3 of 17
AllenJessup
You can check the path by using (findfile "acad.pat") on the command line. It will result in the first path if finds an acad.pat file.
Allen Jessup
CAD Manager - Designer
Message 4 of 17
paullimapa
could you attach the customized acad.pat file here so we can all try on our end?
Paul Li
IT Specialist
@The Office
Message 5 of 17
Kent1Cooper
If you added it at the end of the file, I go along with @pendean's question about whether there's a blank line at the end.  [I don't think it's needed before the definition.]  A .pat file must not end with the end of the pattern code, but that end of code needs to be concluded with an Enter.  Some people put a * [which AutoCAD ignores] on the last line so they can see that the there is a conclusion to the code content of the last definition.
Kent Cooper, AIA
Message 6 of 17
DJB266
I'm getting an "unknown command" message.
Message 7 of 17
DJB266
I've tried with blank spaces above and below.  For what it's worth, I don't have blank spaces above or below the ceiling tile code described in my post.
And yes... several acad restarts and several computer restarts.
Message 8 of 17
DJB266
It's tucked in the middle - just like the ceiling tile code.
Message 9 of 17
pendean
Community Legend
Community Legend
Did you edit the correct ACAD.PAT file? How do you know it is, how and where did you find it?  I think that's your actual problem, you edited a PAT file that is not being used by your AutoCAD session.
The tip offered to you works fine, you have to type this at the commandline exactly as shown, nothin added or removed, you hit the <enter> button afterwards to invoke it
It works for all of us using AutoCAD in WindowsOS (the topic of this forum).
Message 10 of 17
DJB266
 Copied and pasted into the command line.
Message 11 of 17
DJB266
Everyone seems certain that I'm using the wrong path.  Here are screen shots of where the pat file is and where acad is looking.  They are the same.  As is evident in the ceiling tile code being visible and usable.  I know it's not the path.
Message 12 of 17
Kent1Cooper
@pendean wrote:
....Did you edit the correct ACAD.PAT file? ....
That would have been my first guess, too.  I can imagine there being more than one ACAD.PAT file around, probably from something like an altered one carried over from an earlier version in addition to a "raw" one coming from an upgrade installation, and AutoCAD might be looking at the wrong one.  But if their custom ceiling patterns are there and available and they work right, then for this situation to be the problem would require that there are more than one such file that both [or all] have those ceiling patterns added into them, and that they added this new one to the wrong one of those files.  That seems pretty unlikely.  But it's still worth using (findfile) to determine exactly which file at which location it's looking at.
And by the way, it's not a fault in the pattern definition itself.  That works for me, both when put into its own separate .pat file and when added into my ACAD.pat file:
Kent Cooper, AIA
Message 13 of 17
Kent1Cooper
@DJB266 wrote:
You need to copy and paste the whole line including the parentheses.  It's not a command, but an AutoLisp function, and it requires those, which is why Message 9 includes the warning "nothin added or removed."  The image indicates that you omitted the parentheses.
Kent Cooper, AIA
Message 14 of 17
DJB266
Thanks for clarifying.  Done.  Confirmed it's the same file I've been editing.  Not a path issue.
Message 15 of 17
DJB266
Auggh!  I don't get this.  I don't get this.  I'm following the right path.  It works for the ceiling grid pat, but not for this.
Message 16 of 17
Kent1Cooper
They are not the same.
That shows that it's looking at the version in the folder without the further sub-folder \\pats at the end, which is where the one indicated here is:
Kent Cooper, AIA
Message 17 of 17
DJB266
Thank you!  I'm apparently an idiot.  At least I know now.
