PASTECLIP IGNORE
PASTECLIP IGNORE
pcwortex
PASTECLIP IGNORE
pcwortex
Hi communyti,
I try copy object from one draw to another draw, but I get error "Command: _pasteclip Duplicate definition of block 1_1010200000_PART61693339175_0_in_10102000001693339175_7 ignored.
Duplicate definition of block 2_1010200000_PART51693339175_0_in_10102000001693339175_7 ignored.
Substituting [simplex.shx] for [ISO8.shx]"
How solve this problem.
tramber
There is no error !
When a definition of a block exists in a drawing you need to export the block (or the "sub-block") and import it in the target drawing with an update. In order to update. Unless you don't need to update ! In such a case, there is no error.
For example :
to be wblocked somewhere (WBLOCKcommand) and inserted again from its new place to the target drawing with INSERT.
A block can be updated but not a sub-block. It needs its own process.
Copying and pasting is not a way to update at any level. But, still ; not an error.
pcwortex
Ok, but for me need this block, then where I can find it?
tramber
The blocks are in the source and target drawings, no problem.
Maybe you miss the font ?
https://forums.autodesk.com/t5/autocad-r12-r13-r14-archive-read/iso8-iso10-fonts-needed/td-p/3129380
pcwortex
if I create new drawing page I can paste draw, but only where need I can not copy and  don't undestand why.
pcwortex
solve problem with rename function
