Paperspace shortcut command
I am currently working on a drawing, freezing and locking in paperspace. I need to switch often to get out of the view port and would like there to be a shortcut command that doesn't stretch the whole length of the keyboard.
I am wondering how do I change the shortcut command of "PS" to something different. I could not find it under manage>customize>user interface.
Thanks, Lauren
cadffm
Create what you want, the command is PSPACE.
Or use the [Model]\[Paper] toggle button in statusbar.
Or just doubleclick in paperspace area.
Sebastian
I'm trying to located where I can change the command to what I would like. When I zoom into a viewport too far, I have to use "PS" to get out. I would like to work more efficiently so I am looking for a solution where it can be a 1 button commands to get out of viewports
cadffm
If you don't know where/how to create a shortcut or alias to command pspace,
use the Model/Paper toggle button in your status bar.
Statusbar1
Statusbar2
Isn't an option for you?
In F1-Help is also the information about ALIAS PGP and SHORTCUT customizing.
Sebastian
I see what you are talking about now! I never realized that was a toggle button between the ports. I was only taught the command on the keyboard! Thank you!
