paperspace problem
paperspace problem
No aplicable
Hi there
i have drawn in all my lines such as insulation , dpc , breather membrane and other lines with patterns.
however when i take them over to paper space they suddenly turn absolutely massive.
does anyone know whats wrong as this is due on monday and im bricking it a little
thanks
0 Me gusta
Responder
Soluciones aceptadas (1)
426 Vistas
4 Respuestas
Respuestas (4)
ara_neresesian
HI
There is  lot of reason for it.
(vport size , annotation scale ,paper size,...)
Please Send your dwg file to forum to explore more  .
Good Luck
john.vellek
Hi @Anonymous,
Ara is correct that there are too many things that can cause this to happen for a single answer to be provided. Please attach a sample file and I am happy to look at it for you.
John Vellek
No aplicable
@john.vellek @ara_neresesian
thanks for your replies
I've actually managed to partly solve the issue by  changin PSLTSCALE from 1 to 0.
HOWEVER!
I now have to go through every drawing and redraw all the insulation lines as that's the only way it will work.
is there a short cut for this? or has it just got to be done?
thanks again
Matthew
0 Me gusta
john.vellek
Solución aceptada
HI @Anonymous,
How are the lines drawn? Are they a specific linetype? Are all the properties set to bylayer?
You could use the Action Recorder to create a macro perhaps that would change them to a different linetype.
I will need to see a drawing in order to offer more.
John Vellek
0 Me gusta
