>>"however need to have 0,0 point on right bottom corner"
Why?
>>"My acad2023 shows 0,0 point in the middle of the page."
Because you draw your object around the UCS 0,0,0 point..
Move your object to the position you want (and I can not see the benefit of it)
or move the UCS to the position you like.
Command: MOVE or UCS
Your picture shows the World coordinate system (WCS),
you can set up a UserCS(UCS), but you can't move the WCS.
If like liek to have the WCS 0,0,0 there, start to move your objects..
>>"Any chance to set it up, so ALL paperspace will match same right bottom"
Explain WHY you like to have the UCS 0,0,0 there, then we can help much better.
(Note: We don't know where your objects are in the other layouts, also not in other files)
From one who creates dynamic block I think you don't ask for "How do I change my block basepoint", right?
