Paperspace lineweights outside of viewport
ryan_cousins
ryan_cousins
Community Visitor
Community Visitor
If I draw a line directly on the layout/paperspace (no viewports added, yet) the lineweight will only show if I change the "VP Lineweight" in the layer properties. But my understanding is this is meant to change lineweights for anything inside a view port. I'm working on a layout where I haven't inserted a viewport, so shouldn't the lineweight be based on the regular lineweight?
paullimapa
The layout itself is also treated like a vport
Paul Li
IT Specialist
@The Office
cadffm
But it should work as expected with the normal layer lineweight setting aswell
- IF object lineweight is set BYLAYER (it is, in your sample)
- IF there is NO VP LINEWEIGHT OVERRIDE for this layer!
Remove layer overrides and test it again!
Do you know how to do this?
Sebastian
pendean
Community Legend
Community Legend
@ryan_cousins is this a problem in ALL of your viewports in ALL of your DWG files, or just this one viewport or just this one DWG file?
What is SHADEMODE set to inside your viewport?
ryan_cousins
Community Visitor
Community Visitor
Thank you for your help, everyone. It turns out I had to remove the layer over ride. Good to know!
