Paperspace line types not matching model space
itsnathanblake
itsnathanblake
Hi guys,
I am having an issue with the linetypes in a paperspace not matching those in the model space (Xref)
the model space is an xref but even when the xref is attached the line type is showing completely different.
I have tried changing the PLTS and MSLTS and still no different please send any tips to solve this.
Valentin_CAD
@itsnathanblake ,
LTSCALE = 1
MSLTSCALE = 1
PSLTSCALE = 1
CELTSCALE = 1
Suggest you check these on ALL drawings (including Xrefs).
In addition, check the "Linetype scale" in Properties is 1 and that the linetype Manager Global /Current scale is 1.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
ian.mag
Hi @itsnathanblake
I would suggest you use the same template for both the XREF and the base file.
What works best for me is setting the MSLTSCALE and PSLTSCALE both in model and and the paper space as 0. Same scale as shows perfectly as seen in the model space. Let us know what these system variables read on your end.
