Paper space not allowing to move objects....
Message 1 of 9
I was copying titles in Paper Space, all of a sudden I can't copy or move anything. Allows me to select then the cursor disappears from the screen? Have I accidently changed a setting? Thanks.
Replies (8)
Message 2 of 9
leothebuilder
Check if the layer(s) are locked.
Message 3 of 9
pendean
Community Legend
Community Legend
... or you slipped into or out of the viewport: hard to tell since your description is light and there is no screenshot or video.
Message 4 of 9
No layers are locked at all. Strange, if I type any command, say move or copy or line the cursor jumps to the bottom left of the page (0,0?) and remains there frozen until I hit escape. I have 3 small viewports?on the page but this occurs outside of these in paper space. ?I hope that makes sense! Thanks.
Message 5 of 9
Do you have the same behavior while in model space?
Message 6 of 9
GrantsPirate
Just to eliminate one obvious problem, turn SNAP off, not Osnap, but SNAP (F9).
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 7 of 9
emily.bousaada
Observer
Observer
Try clicking Ctrl + B: this is a block toggle to the origin of the layout plan
Sometimes I have accidentally clicked it when I'm using Ctrl + V to paste in callouts
Message 8 of 9
Thanks so much, I was having the same problem, it was driving me crazy. And yes, it was after I had been using the CTRL+V for paste, so I tried the CTRL+B, and that solved the problem!
Message 9 of 9
Thank you so much. You saved my life. I was having the same problem here. You deserve the best!!!
