Paper Border vs. Print Border
MarkFitz
MarkFitz
I may have asked this before, but, how do I correct/prevent this from happening?  Prior to my last print, where I wanted to see just the details, the white paper filled the drawing border, now it only covers what I printed.  Is there a way to lock this feature?
MarkF
imadHabash
Prepare a pagesetup for your plotting issues.
Imad Habash
tboehler
For the actual formatted print have the "Save changes to Layout" checked on.  Uncheck it when doing these test plots.
and/or
Create a "Page Setup" for different plotting needs.
MarkFitz
My initial page looks correct, with the white covering the whole drawing border.  It's only when I print something that's not this, i.e. I print a section within that border, that it changes the shape/size of the white background.  How do I stop this from changing, or how do I change it back to show the full border as white?
MarkFitz
I have page setups for the plotters I most commonly use (full size D, and  DWG to PDF), so it's only when printing any portion of this I should uncheck the box?  This makes sense!
tboehler
yes.  unchecking it will not save the "area" you print.
cb94030
Thank you MarkFitz 81 for asking that question. I also have the same issue.
