AutoCAD Forum
Panning with Logitech M560 Mouse
15 REPLIES 15
Message 1 of 16
3950 Views, 15 Replies
Whenever I use the middle button to pan, it switches between open tabs. For example, If I have a file open and the Start Tab is beside it, when I click and hold the middle button to pan in my file, it switches to the Start Tab. I am using a Logitech M560 Mouse. Before you ask, Yes, I did download the appropriate mouse software and programmed the middle button to be used in this fashion. I was using the function fine for several weeks up until this morning when I opened AutoCAD and this issue started.  I am using AutoCAD 2017 Student.
Tags (3)
15 REPLIES 15
Message 2 of 16
TheCADnoob
what is the value of MBUTTONPAN?
CADnoob
Message 3 of 16
in reply to: TheCADnoob
MBUTTONPAN = 1
Message 4 of 16
TheCADnoob
Message 5 of 16
TheCADnoob
I might also double check the button assignments in the driver utility. Sometimes i have better luck with generic windows drivers with some peripherals so you can also try uninstalling the driver as well.
CADnoob
Message 6 of 16
Thank you! This worked - at least for now.
Message 7 of 16
TheCADnoob
glad to have helped- at least for now hehe
CADnoob
Message 8 of 16
Unfortunately this was only a temporary fix. It is no longer working. I have no idea how that makes any sense - how it could work for a while then stop working again without me changing any settings is baffling.
Message 9 of 16
TheCADnoob
did the values in your CUI change?
CADnoob
Message 10 of 16
No, they did not change. After I changed them as it told me to, the CUI value remained the same after I closed the CUI window. I even re-opened it to check and made sure that I had hit "Apply" before closing.
Message 11 of 16
TheCADnoob
Message 12 of 16
So essentially it is saying that the mouse may actually be the problem, not CAD itself. That makes sense I suppose, but it is just strange that it would work flawlessly for several weeks and then suddenly stop working. I can always buy another wireless mouse to use for CAD and see if that makes a difference. Thank you so much for your help, hopefully that will solve my problem.
Message 13 of 16
TheCADnoob
Im about to murder my M570 cause of a bad button so its not beyond the scope of possibilities that its the mouse. it does sound like an odd problem though. Does it functional as it should in other programs?
CADnoob
Message 14 of 16
RobDraw
The Logitech SetPoint software has created problems for me in the past. When not installed, no issues.
Rob
Message 15 of 16
This problem occurs when you use some models of Logitech® mouse [like my M560], that changes the regular escrow to smoot mode when you press the wheel.
The way I find to solve it in Revit® and CAD® was use the command “PAN” at the keyboard, and them use the left bouton to pan. Otherwise, I use also my old M280 mouse in such programs, due it don´t have the dual mode wheel.
There is the only way to solve your problem. That´s all my friend. Thanks TOM.
Message 16 of 16
RobDraw
Not true. Other solutions and possible causes were given.
Rob
Forma Design Contest
AutoCAD Beta
