Anuncios
Pallet Text Size Issues
MatTheDrafter
MatTheDrafter
We just started to use Windows 10 in the office and had to do a new installation of AutoCAD on all machines. Now on some of the machines, there appear to be a text sizing issues in the Pallets, such as the properties pallet. If you check the image attached the text size is way larger than it was before the reinstallation. The strange part is it is only happening on some of the machines the rest it appears the normal size.
Does this have anything to do with using 4K monitors?
0 Me gusta
Responder
337 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Which version of AutoCAD?
The background of the question is that your issue is based on 4K displays and that is supported since 2017 Update 1.
Older versions of AutoCAD can either use a lower display resolution (so it's not the preferred resolution for your display) or set the Windows text scaling (dpi scaling) back to 100% (or max. 125%) which results, when full display resolution, that the text is quite small.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
MatTheDrafter
I'll test this out and let you know how ti works.
0 Me gusta
