Overkill opening polylines, mpedit creating overlapping lines?
Dear Sir/Madam
I have a same problem in using Overkill command.
when i am using this command sometimes omit older lines and sometimes omit new lines that duplicated.
I changed tolerance to 3, 7, 10 ,0.001, 0.0001 and ... but it does not work correctly.
What should i do?
Sincerely,
Ahmad
TheCADnoob
could you provide an example file?
Some things i have seen have been slight difference in dimension which cause it to overlook the lines as well as not toggling the correct ignore features. Also check to make sure that they are on the same Z and that the lines do not have a thickness applied to them.
CADnoob
wispoxy
0.0001? The default it 0.000001.
See image attached. It's how mine is setup (default).
