Overkill issues
Overkill issues
Darwin33
Message 1 of 8
Overkill issues
Darwin33
I am experimented some problems using overkill feature in autocad 2017. Sometime you copy entities one over another in the same layer so you have multiple objects with same properties superposed in the same layer that make your dwg file so heavy so you can manage it properly.
But I am no  able to use overkill, bcz it deletes everything. My porpouse is to delete all the repated objets, lines, polylines but not do delete the original one. I want to delet all repeated objects in one layer with same properties. Its important to emphasize that I dont want to delete objects with different properties ie, diferent line typies, regardless they have the same geometry and they were located in tha same layer.
Please could anyone tell me which options I should mark in the overkill pop up dialog.
Thank you
Replies (7)
Message 2 of 8
Vinayv4v
Hi Darwin,
Try this settings and check if it works.
Cheers,
Vinay Vijayakumaran
Message 3 of 8
Darwin33
Thank you
I ll let you know my experience
Message 4 of 8
Darwin33
it s seems works properly now with that settings, but what is the diference if I mark the layer option.
Best regards
Message 5 of 8
Alfred.NESWADBA
When the layer(-ignore) option is checked then AutoCAD identifies objects as equal even if the layers of the compared objects are not the same.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 8
Vinayv4v
Hi Darwin,
Glad it worked for you.
Check the screen cast to know the difference
Cheers,
Vinay Vijayakumaran
Message 7 of 8
If you have attached any image in the drawing overkill will not work. Try creating a new file and crtl-copy the elements you are interested to, and PASTEORIG these entities. Execute the OVERKILL command in the new file (it will work) and copy back with PASTEORIG in the old file.  You may lose some dimension alineations.
Message 8 of 8
RobDraw
Wrong again.
Rob
