Anuncios
Output PDF is blurry
No aplicable
Hey there,
I've already searched all similar posts and nothing has worked so far.
The problem is that my drawing looks perfectly fine in the model and layout space but when I create a PDF the (hatched) objects become blurry/fuzzy. I have tried different pdf plotters, no difference. I don't have any underlaying pdfs or whatsover, only AutoCAD objects which I drew.
I attached a small .jpeg out of PDF I made (I hope it's visible).
I would be grateful for any help.
Thank you.
0 Me gusta
Responder
2.798 Vistas
5 Respuestas
Respuestas (5)
No aplicable
Try to use bluebeam.
0 Me gusta
imadHabash
would you please attache here the parts that become blurry/fuzzy as CAD drawing?
Imad Habash
0 Me gusta
No aplicable
Here is the attached .dwg file. When I make .pdf I become blurry objects.
0 Me gusta
No aplicable
Here is the attached file.
0 Me gusta
imadHabash
as you see from attached pdf file there is NO problem. please try yo use the same settings and try again.
if the same still happened then try to Reset AutoCAD to default settings. >> Reset <<
Good Luck...
Imad Habash
0 Me gusta
