OSM
OSM
Message 1 of 13
OSM
HI
I want insert terrein in my map DWG and can I use osm [open street map) if it is ok.Could you tell me how can realize this
Replies (12)
Message 2 of 13
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
I haven't tried inserting an OpenStreetMap into AutoCAD before. I believe it exports map data in a OSM format which means you will need to convert the format to KML or KMZ in order to get it to work with AutoCAD. Here is a link I found to a converter that might do the trick for you.
John Vellek
Message 3 of 13
Hi john
I saw that link it's very nice but I have one question why i can't find autocad format at number two at export format of this link
Message 4 of 13
john.vellek
Hi @Anonymous,
You are welcome to attach your data and i can try to run the conversion to see what I get. I believe the KML option is the one you will want to select when you perform your conversion.
John Vellek
Message 5 of 13
Hi I have see some idea on forum for use cogo cormmande but there are not enough for me Could tell me more example for use this commande
Message 6 of 13
john.vellek
Hi @Anonymous,
Can you tell me the desired end result of this process? I believe that if you convert the OSM file to a KML file you should be able to use the GEO command in AutoCAD to bring in the data.
The COGO command is an AutoCAD Civil 3D command as described here.
John Vellek
Message 7 of 13
hi
John yes I use Geo command result fine it's ok.But I use Autocad map 2013 and here it is COGO command do you have any discrobe for this command on video or letter example
Message 8 of 13
john.vellek
Hi @Anonymous,
Perhaps this Youtube video will help you with the Cogo command.
John Vellek
Message 9 of 13
I have see this video but on my compiuter i have autocad map 2013 and on taks pane on video it look commnd edt on autocad map 2010.But on my autocad map 2013 in taks pane command edit didnt exist how can find this?
Message 10 of 13
john.vellek
Hi @Anonymous,
Perhaps this article will help.
John Vellek
Message 11 of 13
Hi
John all your example or video are for autocad civil not for autocad map 2013 but however thank you for your help and also your answer
Message 12 of 13
Hi
John i have anothe question I have use ALIGN command for jpg photo and I insert this on dwg map but the measure of map it's diffrent of jpg question
It's possibly of stretch the jpg photo from ALIGN command
Message 13 of 13
john.vellek
Hi @Anonymous,
Yes, you can use the align command to scale, move, and rotate.  Here is an AKN Article that describes how to do this.
John Vellek
