Ошибка установки
Ошибка установки
Ошибка установки
При установки версий AutoCad2015 и AutoCad 2016 выходит сообщение" Установка не возможна. Не установлен(не обнаружен) NET.Framework 4.5". Установлена версия NET.Framework 4.6
john.vellek
Hello @Anonymous
I understand that you are experiencing .NET errors when trying to install your products. You will have to uninstall the .net 4.6 and then reinstall after the Autodesk products are installed.
Please see AKN Article AutoCAD LT 2015 Install not working
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hello @Anonymous
Were you able to try my answer to see if it resolved your problem?
Please post your results for other Forum users.
John Vellek
john.vellek
Hi @Anonymous,
I’ve just accepted the response to your post (linked here) as a solution with the understanding that it is the correct answer.
If my response did not work as an answer, please reply to the previously linked thread so that I can unmark the solution, and we can continue the conversation.
No action is required if my response did work as an answer, however I wanted to point out that if the opportunity arises again you can also click on the ‘Accept as Solution’ button if/when relevant so that others can more easily benefit from the information. Please feel free to let me know if you have any questions or concerns!
John Vellek
