Ortho not working using F8 function key (problem sovled)
kylei7449
kylei7449
This is for information only if some other users encounter the same problem with using the F8 function key.
Situation: I just installed a fresh copy of Windows 10 on my PC and reinstalled my programs (including ACAD 2015). Well, I quickly discovered that every time I hit the F8 key to turn on/off Ortho, my cursor crosshairs would change to a magnifier circle and the frame around Model Space would turn orange in color. (and Ortho would not work) Only way out was to hit ESC. I could use Ortho but only if I selected it at the bottom in CAD's system tray (icon row).
Here was the problem. I have MOVAVI screen capture app installed and running in the background at system Startup. I found this out after the MOVAVI screen capture opened after repeatedly hitting F8. Closing the application returned the function key F8 while working in Model Space. Problem finally solved.
john.vellek
HI @kylei7449,
Thanks for the information. I am not familiar with that app but I am sure that other customers that use it will be happy to see your discovery.
John Vellek
EricHutchins2946
Community Visitor
Community Visitor
I have a desktop computer running Windows 10, Autocad 2024 and the Movavi screen capture program.
After running Movavi the Autocad F8 and F9 keys do not function as expected.
Here is a solution that works for me:-
- Activate Movavi
-  Click the settings icon on the Movavi control tab
-  Select Keyboard Shortcuts
-  At the botom of that window select "Disable keyboard shortcuts"
-  Select OK
The next time you open Movavi it should not take-over the F8 or F9 keys.
Voila!
Regards
