Options on Annotative blocks Not visible on Multiple selected Blocks
No aplicable
Since I use Autocad 2020 / Architecture 2020,  I have the following issue:
When I select just 1 annotative block I Ihave the posibility to select "annotative Object Scale" in the Quick-Menu (Right Mouse-button)
I can't see the "annotative Object Scale" options in the Quick-Menu (Right Mouse-button) when I select multiple annotative blocks.
(See screenshots)
Anyone who knows how to solve this?
Thanks in advance
Nico
0 Me gusta
Responder
Soluciones aceptadas (2)
995 Vistas
5 Respuestas
Respuestas (5)
vinodkl
Hi @Anonymous
Sorry, that's how it works. The option of "annotative object scale" won't show up when you selected multiple annotative blocks. May I know what you are trying to achieve after selecting multiple objects? There are different command which you can use to add/remove/sync the scale of the multiple annotative blocks selected:cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
No aplicable
Hi  @vinodkl
For Now I select 1 Block and select the annotative-command I would like to use. then I Select all the blocks from that specific type (Via Filter) and then I use "Recent Inputs" ... to accomplish what I want to do ... But that's always in 2 steps, where I could do this in the past with the previous releases in one step.
so sad that the possibility has removed/gone.
Cheers,
Nico
0 Me gusta
ВeekeeCZ
Solución aceptada
Don't think so...
Anyway. You can use Ribbon to add a scale to multiple annotations. Annotate/Annotation Scaling on the right.
Or... go to CUI and change the Ribbon. See my Default Ribbon tab:
Or go to CUI and fix the Shortcut menu. Then you can have this option for not only multiple block selection but for any annotative objects selected.
No aplicable
@ВeekeeCZ
Thanks for the suggestions.
I will do that.
Cheers,
Nico
0 Me gusta
vinodkl
Solución aceptada
Hi @Anonymous
You can select multiple annotative objects and then use the command "AIOBJECTSCALEADD" to add the current scale to the object and to remove the scale you can use the command "AIOBJECTSCALEREMOVE" and command "OBJECTSCALE" to add other scales to multiple annotative blocks:cara_con_una_leve_sonrisa:
