Anuncios
Opening drawing, 3D Solids have moved!
No aplicable
Hi, never seen this strange problem before. Upon starting up AutoCAD and loading up a model containing 3D solids, some of the solids have moved from where they were when I saved at the end of the last session. Their correct location is still shown in ghosted/wireframe form. The only way I've discovered that gets round the problem is to explode the solid, immediately undo and then move back to the correct position, which is a pain.
I've attached a screenshot of the model which shows a pipe support which has moved overnight - anyone seen this before and know the cause of the problem?
0 Me gusta
Responder
249 Vistas
1 Respuesta
Respuesta (1)
S.Faris
I'm not fully confident with this, but as a trial and error troubleshooting step, try using the BREP command on the affected solids and see that gets things sorted out. Also select all the solids and in the properties dialog change the HISTORY under SOLID HISTORY to NONE
Reference Material : https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
TRY THIS : https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/3D-obj...
SALMANUL FARIS
0 Me gusta
