Hi, I am a CAD novice. The architect I am working with uses ArchiCAD and I use AutoCAD (2008 version), I have downloaded the Autodesk DWG Trueview 2017 so I can view the dwgs but not manipulate them or import them into AutoCAD, is this possible?
Thanks for your reply. They did email me the dwgs and I couldn't open them in AutoCAD, that's why I downloaded the Autodesk DWG Trueview, but I can only view them and not manipulate them. Sorry, my skills are basic, is there a way in which I can open them in AutoCAD?
Then use Autodesk DWG TrueView to open the drawing, and now save it back to DWG2007 format (using command _SAVEAS and selecting the filetype).
This file can then be opened with AutoCAD 2008.
- alfred -
Sorry to be dumb but I can't how to save the file on the DWG Trueview. I clicked on convert (to 2007)
You are correct, it's called convert in DWG-TrueView as described >>>here<<<.
- alfred -
There were some great post that seemed to help. Were you able to get all of your questions answered?
Also, please select Accept as Solution for post or post's in this thread that helped resolve your issue, or reply with additional information if the problem persists.
Thanks.
