Opening a .dxf file
Opening a .dxf file
Message 1 of 22
Opening a .dxf file
Hello, I am trying to open a dxf file to check the content but I do not have autodesk. I just need to make sure that there is no specific personal information like address or website going with the drawing. i need to send that drawing to a 3rd party. I tried the online viewer but I do not think it shows all the information in the file. Can anybody help me just open the file (I can send in private message) and tell me what they see?
Thank you
Dan
Replies (21)
Message 2 of 22
tramber
Just open it in a notebook, as easy as that !
You can change the extension to .txt if necessary. But DXF is not compressed or encrypted !
Message 3 of 22
I did that. But does the txt file will show all the information that are contained in the dxf file? Like adress, side notes, websites, contact information....?
Message 4 of 22
Valentin_CAD
@Anonymous ,
Download an Autodesk viewer to view CAD, DWG, DWF, DXF files and more.
Just drag and drop:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 5 of 22
tramber
For sure. It contains all.
Message 6 of 22
pendean
Community Legend
Community Legend
Who created the DXF file? What program created it? What control did you have on source content and the creation content/process?
Or there are dozens of online and downloadable DXF file viewers on the web, help yourself https://www.google.com/search?q=dxf+viewer
Message 7 of 22
I tried the viewers already. They only show me the drawing. What I am concerned about is what kind of personal info does the file show: such as address, side notes, websites, contact information....? I am fine with sending the address but I would like to make sure that the file is completely neutral about sources and personal information. Let me know.
Message 8 of 22
pendean
Community Legend
Community Legend
@Anonymous You'll not find that sort of info in a DXF file if opening it in any viewer or MSWord or Windows Notepad reveals nothing you are concerned about.
Find and pay someone to vet your files for you in your region if this is a dire personal or business need.
Good luck.
Message 9 of 22
So you are saying that if I don't find anything in notepad or in a viewer, I should not be concerned about any revealing info?
Or you are saying that I cannot be sure if I don't pay someone just to open the file and check for me?
Message 10 of 22
Patchy
If you want to see what's in the .dxf then download Autodesk Trueview (It's FREE)
Open the .dxf file, go to Properties.
1st tab will show who started the drawing.
2nd tab will show nothing or Information the Author manually put in the drawing as the example here:
(If nothing in these tabs, there are nothing you should be worry about)
Message 11 of 22
pendean
Community Legend
Community Legend
@Anonymous Correct on all counts: your legal concerns and urgent needs should not be left to strangers on the web who have no direct impact on or pay any repercussions for suggestions they offer.
Ask your legal counsel all about how to protect yourself the proper way.
Message 12 of 22
@Patchy!!!That's great!! I just download this freeware and I open the .dxf file. I do not find anything in the properties. The file just shows one drawing with 3 tabs: Model, layout1 and layout2. I do not see any written information. The strange thing is that when I open the .dxf file in a notepad it shows me some information like author, title of the drawings...that I do not see in the autodesk trueview. Does it make sense?
Message 13 of 22
Patchy
No, not the drawing tabs. Use the drawing Properties
Message 14 of 22
Yes I went there. Just the name of the author. Nothing else. Can other information can stored elsewhere? Thank you SO much for your help by the way 🙂
Message 15 of 22
Patchy
That's all.
The rest of the .dxf shows the elements in the drawing, their properties, dates and how it setup to plot.
Message 16 of 22
I see. Great. So it's funny that when I open the file in the txt notepad, it shows the tile of the drawing and I cannot see this info into autodesk trueview
Message 17 of 22
Patchy
Take a snapshot and show it here, it could be the name of the xref drawing.
Message 18 of 22
screenshotscreenshot
Let me know if you know where to look. In the text file, it says "glass dome"
Message 19 of 22
Patchy
Immediately after open this .dxf
Press the F2 key, does it say    XREF Glassdome?
If not, it is a block in this .dxf
Message 20 of 22
By pressing F2, this is what I get:
What do you mean by block in this dxf?
