open pdf as default after publishing
how to set the program to automatically open pdf when publish to pdf. Thanks
chriscowgill7373
There is a check box in the publish dialog to open the odd in a viewer when it is done.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
I have looked and looked as well as tried different forums but I don't have this button. Is there somewhere else I should be looking in Autocad 2019
See Attached
RobDraw
Rob
S.Faris
If you are using ADOBE PDF printer, then insid ethe custom properties there is an option called "VIEW ADOBE PDF RESULTS", tick that one.
If you have PLOT IN BACKGROUND or PUBLISH IN BACKGROUND ticked, then the output will not open in the PDF viewer.
SALMANUL FARIS
