Anuncios
Open drawing as read-only
No aplicable
I often need to open drawings stored on a network share just for viewing and checking dimensions and I don't want to interfere with other users trying to open these files for editing. Is there a way how to open a DWG from a file manager directly in read-only mode?
Walter
0 Me gusta
Responder
Soluciones aceptadas (3)
41.486 Vistas
14 Respuestas
Respuestas (14)
stevetamplen
Solución aceptada
Hello Walter;
It is really just as easy as opening AutoCAD, clicking on Open Files, highlight the drawing you want to open, then click on the little dropdown arrow to the right of the OPEN button, and choose Open Read-Only.
I hope that helps!
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Steve Tamplen
Technical Support Specialist
dgorsman
Solución aceptada
Also consider using DWG TrueView - thats *always* in read-only.
stevetamplen
@Anonymous
Did any of the posts get your problem resolved?
If so, please hit the Accept as Solution button for that post so that more community members can profit from the solution.
Steve Tamplen
0 Me gusta
stevetamplen
Hi @Anonymous
I marked several posts as Accepted Solutions for this question. This helps other Forum members find answers more quickly!
Steve Tamplen
0 Me gusta
No aplicable
No this does not help and will not work. it still locks the file from other being able to work on them.
0 Me gusta
RobDraw
Can you be more specific? AFAIK, all of these solutions work.
Rob
0 Me gusta
No aplicable
YES ARE CHECKER OPENS FILES READ ONLY WITH AUTOCAD AND IT LOCKS EVERYONE ELSE OUT OF THE FILE IF EDIT WORK IS NEEDED AS IF HE JUST OPEN THE FILE STRAIGHT UP.
0 Me gusta
RobDraw
I have not seen this happen before. Maybe he needs to make a copy of the file so that he doesn't lock other users out.
Rob
0 Me gusta
No aplicable
It is a windows setting somewhere because I had the problem before at another location.
0 Me gusta
RobDraw
When you find it, please share.
Rob
0 Me gusta
User_2011
Other way is open the file, then open again, you will be prompted to open as read only, close the other instance...
0 Me gusta
georgeblazek02
Observer
Observer
I wish you could just right click directly in Windows Explorer and have that Open Read-only choice there.
Trying to navigate through many folders directly in AutoCAD is slow. I wish AutoCAD would have better browsing interface in its Open - Select file dialog box.
The method to go around that:
1. In Windows Explorer right click for Properties and tick Read-only. Then click on file to open and confirm Read-only.
2. While the file is open in AutoCAD go back to the Windows Explorer - Properties - un-tick the Read-only.
3. Now you have the file open Read-only and in its original location is available to other users for editing.
RobDraw
[start sarcasm] That's four more clicks every time a drawing needs to be opened. [end sarcasm]
Rob
0 Me gusta
