open command does not give me a window
mechdesign21
mechdesign21
Why would my open command start doing this. makes it very hard to find a drawing.  did i make this happen somehow?
Thank so much in advanced.   I have no idea how i accomplished this, It just started like magic.  I would like to have a window like always had when i type open or utilize the open command.
DarrenP
type filedia then 1
DarrenP
user181
Set FILEDIA to 1
paullimapa
in addition to the other's answers you can also at this point hit the ~ key & then Enter key on the keyboard to bring up the window.
Paul Li
IT Specialist
@The Office
nrz13
The fix has already been reported here, but to answer your question on how it happened, it is most likely a bug in AutoCAD.  It could be an issue with a custom LISP, if you use those, but our LISPs do not have any trouble and this glitch still pops up from time to time.
I would suggest entering SYSVARMONITOR at the command line and setting a watch for FILEDIA to see when it gets changed.  It should alert you if it's changed and then you can maybe get an idea of what caused it.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
mechdesign21
thanks so much your awsome
mechdesign21
I guess filedia is the file dialog box.  thanks so much!!!
