Onsanp not working
mthardwick
Onsanp not working
mthardwick
Hello
Snap has just stopped working for me. If I look at the status Snap is turned on looks like it should work. On my screen if I move the cursor around it does not pick up on end points.
If you could offer some suggestion to rectify that would be great.
Mark
0 Me gusta
Responder
Soluciones aceptadas (2)
632 Vistas
11 Respuestas
Respuestas (11)
Alfred.NESWADBA
Which command is active while you move the cursor?
What setting is reported for sysvar OSMODE?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
mthardwick
Hi Alfred
I am trying to use snap for measure or line command - each one the cursor is not coming up to snap.
If I put OSMODE in the current value is 20719?
Mark
0 Me gusta
BeKirra
I think it is worth try regenall when it happens.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
mthardwick
I tried regenall all but it did not work.
0 Me gusta
BeKirra
What if set UCS to "world"?
X² + Y² = C²
0 Me gusta
mthardwick
I tired that. Still no luck.
Mark
0 Me gusta
BeKirra
What if restart AutoCAD?
BTW does it behave with all drawing files?
Edited: Another thought - please try osnapZ
X² + Y² = C²
0 Me gusta
mthardwick
Sorry that did not work - onsnapz
I problem occurred yesterday and I shut down compture over night and problem back so I have tired a re-start.
Mark
0 Me gusta
mthardwick
I just tried F3, read of an online forum and it worked. Thanks very much for your help.
Mark
0 Me gusta
Alfred.NESWADBA
Solución aceptada
OSMODE 20719 means OSNAP is off
- alfred -
Alfred NESWADBA
BeKirra
Solución aceptada
You're right. I didn't pay attention to the value OP described.
@mthardwick "osmode" is off when it is set to 16384 or greater.
X² + Y² = C²
0 Me gusta
