online maps
online maps
No aplicable
I tried to import an online map through INSERT - SET LOCATION - ONLINE MAP
A window pops up saying
`you do not have permission to access Online Data Mapgo to ACCOUNT SETTINGS and check your entitlement to use online maps ....´
When I click on account settings and edit profile  it doesn´t let me change anything but my name.
What do I need to do to access online maps in order to use Plex earth pug-in?
0 Me gusta
Responder
375 Vistas
5 Respuestas
Respuestas (5)
Alfred.NESWADBA
There you'll find an AKN article with some suggestions >>>click<<<
Plex Earth plugin is not an Autodesk product, you'll need to ask the vendor of that plugin.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
haiii,
        just update the geographiclocation software. go to auto cad forum--- downloads- select your auto cad version ---- and download the geolocation software back up--- and install ----  then try the online map now your starts to working online mapping.
0 Me gusta
No aplicable
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoc...
 just go to this website & download and intall this service pack then try.
thank you
0 Me gusta
No aplicable
thanks a lot - just one question. Can I use fusion360 (is it the same as autocad 360)?
0 Me gusta
Alfred.NESWADBA
AutoCAD360 and Fusion360 are totally different products.
It depends on your needs to suggest which product will work better for you.
But as you are referring to areal images neither AutoCAD360 nor Fusion360 can use the Geolocation-(Mapping) functionality.
- alfred -
Alfred NESWADBA
0 Me gusta
