Online maps using geolocation
No aplicable
I have a drawing of a highway alignment, I wanted to see this on map, so I converted this file to KMZ and opened it on Google earth and it worked fine, my alignment was correctly placed, Then I thought to bring some changes to the alignment by inserting online map to Autocad, I followed all the steps and the map came to Autocad, but I realised that my alignment has shifted a bit, I tried different GIS systems, but none helped, Why does the same drawing showing differently in google earth and Autocad online map ?
0 Me gusta
Responder
1.265 Vistas
18 Respuestas
Respuestas (18)
Pointdump
Hi Amit,
Welcome to the Autodesk Forums.
More details please. How much shift? What Coordinate System? Are you using Civil/Map 3D? What version?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
0 Me gusta
No aplicable
I am using AutoCad 2017, Using UTM coordinate system. The shift is around 2
meters.
0 Me gusta
No aplicable
Does it have to anything to do with Google Earth and Bing Maps(Microsoft ) compatibility ?
0 Me gusta
Pointdump
Amit,
"The shift is around 2 meters."
2 meters is really not much for "live" aerial services like Bing and Google. I've seen far worse. If you'd like to shift Bing, try >>>This<<<.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
No aplicable
My total drawing of road alignment is around 20 kms, Now I am able to fix the starting point but the whole alignment does not align well, ( the same drawing is fitting exactly when its kmz file is opened in Google Earth).
Why it is good in Google earth and not in Autocad map ( as a designer which one should I follow ? )
0 Me gusta
No aplicable
My initial 3 kms are same in Google Earth and Bing maps (Autocad) but then
the shift starts.
0 Me gusta
Pointdump
Amit,
A couple of screen shots please to show the difference. Or post drawing and KMZ.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
No aplicable
I am attaching the DWG file, the KMZ file is not supported in the Attachment options. I would be grateful to you if you can convert it to KMZ and check that in GE ( I have used Global mapper software for Converting DWG to KMZ) and check this DWG in Autocad maps. ( Rotary is the start of the drawing and go till the last point, you will notice the shift from the midway alignment in Autocad maps,  but no such thing in GE.
Thanking you in Advance.
0 Me gusta
Pointdump
Amit,
"...the KMZ file is not supported in the Attachment options."
Zippola. This Forum will accept anything zipped.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
Pointdump
Amit,
Your drawing didn't have an assigned coordinate system and uses feet units, not meters. I assigned a UTM84-45N Coordinate System and it seems to be the right place. I haven't been able to export a KML/KMZ yet, but I'll keep trying.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
No aplicable
How to assign the coordinate system in AutoCad?
I do not have Civil 3D.
0 Me gusta
No aplicable
I was also assigning the same coordinate system while setting geolocation in from map option.
(Did my drawing fitted well throughout, i mean alignment lines did  not come over existing buildings anywhere?)
0 Me gusta
No aplicable
sharing the KMZ file, Pl go through it, you will notice that initially both on GE and Autocad maps both are showing the same alignment, but after some distance, GE maps show alignment along the existing road (i.e. the survey data), but in Autocad maps, it shows the alignment shifted towards left and not following the survey data.
0 Me gusta
Pointdump
Amit,
I don't know if I'll be much help. My 2018 Civil 3D won't import a KMZ. And QGIS won't import your KMZ, so I can't turn it into a Shapefile. Your Proposed ROW linework looks OK when I assign UTM84-45N to your drawing. I don't have Vanilla AutoCAD to test further. Maybe someone will come up with something.
Dave
Dave Stoll
Las Vegas, Nevada
0 Me gusta
No aplicable
Thanks for the help.
0 Me gusta
No aplicable
Can you please share the DWG file which you have georeferenced from civil 3D, that would be a great help.
0 Me gusta
Pointdump
Here it is, attached.
Dave Stoll
Las Vegas, Nevada
0 Me gusta
No aplicable
Thanks a lot.
0 Me gusta
