- Mute
- Permalink
- Report
I was just wondering this because I noticed in other drawings the block hadn’t been changed in other dwgs.
A Block is defined inside your DWG/DXF where it is,
it has nothing to do with data from other drawings
(except a piece of the content is a Xref)
So the answer is NO.
Attributes updates only by using ATTYNC (or battman and sync option)
and blocks in other files are independent of your file you used bedit.
What you have to do to update a block with the same name in another file:
<two of more possible ways>
Use ADC Blocks-> RightClick on the block in your edited file (after saving) -> ReDefine ONLY
Or User WBLOCK, BLOCK option <select the block from list>
Inside the other files, use INSERT or CLASSICINSERT [Browse..] <select the new created dwg> -> ReDefine YES
Sebastian
