Announcements
OLE producing poor image quality compared to XREF
dave.mawston
dave.mawston
Hi there,
I'm getting very poor image quality from OLE, compared to XREF.
Is there a way around this or is it just the nature of the beast?
XREF:
OLE:
(it's a zoomed-in part of the photo so I don't post sensitive information here)
Some context:
We're making a large amount of files with the same photos on the front/intro pages.
Using XREFs means we have a 'ball & chain' reference folder.
We are hoping to embed the common images in the template file using OLE, so a simple dwg file can be sent between different companies working on it.
Even with the reference folder using a relative path up a couple of levels, we still have to tell them where to put it.
Settings used:
OLE properties:
Publish settings:
We're using AutoCAD Map3D 2024, if that makes a difference 🙂
Thanks in advance!
Replies (8)
Michiel.Valcke
to send files with xrefs you should use the ETRANSMIT command. That will change paths to relative and collect all necessary files in a single .zip file. So the recipient only has to unzip the file and everything will work as intended.
pendean
Community Legend
Community Legend
To answer your question, you can't fix your OLE issue. Sorry.
paullimapa
As @Michiel.Valcke suggested use eTransmit to automatically have AutoCAD collect all xrefs in the dwg into a single zip file. If you don’t want others to have to deal with folder structures then select the option to place everything into a single folder:
https://resources.imaginit.com/support-blog/how-to-etransmit-autocad-files-to-include-xrefs-and-plac...
Paul Li
IT Specialist
@The Office
dave.mawston
Thanks guys, had a feeling this would be the case. I'll give etransmit a go 🙂
Michiel.Valcke
In most places I have worked, etransmits are the norm for packing and sending .dwg's to people that cannot access your file server. Incoming files are often also not accepted if they are not a .zip (etransmit) file.
dave.mawston
Oh right, so etransmit is more for sending via email? That would make a lot of sense, using zip etc.
We use a commonplace server to pass them back and forward, as we're often moving up to a hundred drawings at a time. Will continue as we were. Thanks for the help!
Michiel.Valcke
etransmit is not just for sending by email, I just wanted to illustrate that in many places Etransmit is the only accepted method for transfering files.
dave.mawston
Right, gotcha. Thanks for pointing it out 🙂
