OLE Object / Xref / Binding
jon
jon
I have an OLE Object (image) embedded into file (Drawing A).  I have referenced Drawing A into Drawing B.  I am unable to BIND the referenced Drawing A in Drawing B.  Is this because of the OLE Object?  Any workarounds?
Jon
pendean
Community Legend
Community Legend
1) What does "unable" mean to us: is there a specific error message?
2) As a test, try a different DWG file to bind: did it work or fail?
3) Then try a copy of this DWG file without the OLE. What happens?
What all did you discover?
tboehler
Detach referenced "A".  Insert "A".
Maybe do a PURGE" between those commands.
brian.k.smith
@jon :
The quick answer is "yes, but":
  • As noted here, it is possible to embed bitonal (black and white) images in DWG files through the use of AutoCAD Raster design.   Color or gray scale images are not supported.
  • As noted here, the maximum size of embedded images is around 1600x1200 pixels (a total of about 1,920,000 pixels).
HTH,
-Brian
RobDraw
Remove the OLE to see if it will bind. If it works, insert the OLE into the base drawing in the appropriate place.
Rob
brian.k.smith
@jon :
My suggestion applies to linked images and not embedded OLE objects.   My bad.
-Brian
