06:53 AM
My light fixture schedule is an embedded OLE object, excel spreadsheet. For some reason, when I opened the OLE excel file to edit it today, the excel window opens, I see all the correct data in the excel spreadsheet, but the window is flashing and I cannot click on anything. I can only close it. The window flashes as if there is a notification that has popped up somewhere. (For example when you print a document as a PDF, the window flashes because another window opens prompting you to specify where the PDF should be saved.) In this same way, the excel window is flashing, but there is no additional window that has opened.
