Anuncios
Offsetting polyline
gueorguiev53T4X
Offsetting polyline
gueorguiev53T4X
Hi, im just wondering if anyone knows of a way to offset only one side of a rectangle or polyline. Its clearly possible to select only one side of a rectangle by holding ctrl but using offset then still selects the whole rectangle. I don't want to use the explode command every either so if anyone knows of a way to do that id appreciate the advice.
0 Me gusta
Responder
Soluciones aceptadas (1)
364 Vistas
3 Respuestas
Respuestas (3)
timothy_crouse
Solución aceptada
A workaround may be to perform the typical offset
Then run the trim TR command and trim out the unwanted section of the offset rectangle, no need to explode to use the trim command.
Thoughts?
Best Regards
-Tim C.
ВeekeeCZ
You're right, it's sad that Autodesk never really took advantage of sub entity selecting of light polylines. AFAIK only ERASE command supports this.
gueorguiev53T4X
Yea, that seems like the way to do it at the moment. thanks for the help.
0 Me gusta
