Offset through error
AUTOCAD OFFSET.JPGHi all!
I recently noticed that the function offset is not working properly. The issue is that when I  use offset with through and insert a value, for example 200, the line goes 196.2.
I think it's because I changed a setting without realizing it but
I have no clue how to fix it. Any idea would be great!
Thanks!
jayhar
Enter new value for OFFSETGAPTYPE <0>
Check Dimension Style & Properties, Please upload Autocad 2013 format
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Alfred.NESWADBA
With option THROUGH you are specifying a point, but not a distance.
If you want to have 200 as offset-distance, then don't use the THROUGH option, just enter the distance, that's it.
Why do you get strange results when you are using the option THROUGH the following happens:
  • you are asked to show the object to offset (at a specific point, that will be important later)
  • you selected option THROUGH
  • you positioned you cursor to any position near your graphic and enter 200
NOW ... your current mouse position in relation to your first point (important as described about) defines a vector and entering 200 means for AutoCAD (like drawing a line with the second point):
"From point 1 in direction of current mouse with a length of 200" ... that is the point (again important:) your new offset object has to go through.
And as long as your mouse position is not 90° from your entity and point 1 the offset distance will always be smaller than the distance you enter.
Maybe this video shows the effect, I run offset and along the orange dashed line and that shows that it's just the "through-point" you are defining by start-point/direction/distance:
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
