AutoCAD Forum
Offset showing distance using XY coordinates
3 REPLIES 3
2008 Views, 3 Replies
Greetings. I have always had offset show dimension based on line/object it is offsetting from. However, as of today, it is showing the distance based on my XY position. For example, if my original line is at 106', 174'...when I offset this vertical line to the left, the coordinates are reading 103', 174'.
How do I get this back to showing me that the distance is 3' (from original line) not that it is 103' from X? I think I tapped a function key by accident and that started this whole mess. I've searched high and low with no luck. Any help is most appreciated. - Thanks
Screen shot attached.
3 REPLIES 3
Patchy
F6 or F12 something like that
Kent1Cooper
In the DSETTINGS dialog box:
Kent Cooper, AIA
in reply to: Kent1Cooper
Awesome! Thanks a million! That did the trick!
Technology Administrators
