offset issues
offset issues
offset issues
hi all. please help. i have issue with my offset tool option. it keep asking me to specify distance and also require numeric distance. i used autocad 2013 and it was fine. ever since i switch to 2018 and thi sproblem occurs thats i cant seem to fix. please help
Moshe-A
@Anonymous hi,
well come to AutoCAD Forum!
sounds like you are running some lisp command? if you type OFFSET at the command prompt does this solve the problem?
moshe
Pointdump
Liem,
"It keeps asking me to specify distance..."
That's how the OFFSET Command works.
"I used autocad 2013 and it was fine."
Can you describe how it used to work for you in 2013?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Kent1Cooper
@Anonymous wrote:
.... it keep asking me to specify distance and also require numeric distance. ....
Does "require numeric distance" mean that you cannot  specify the distance by picking two points on-screen, but must always type in a number?  Or that you cannot accept the default distance [or Through] that it offers, but must always answer with a number?
If you type in .OFFSET with the period/decimal-point prefix, does it work as you expect?  If something is loading automatically that UNDEFINEs the command and makes a different definition of it, the . prefix will force it to use the native  AutoCAD command, not the new definition.
And I would also like to know how it worked when "it was fine" for you before:  did it not  ask for a distance?  If not, how would it know where to put the Offset copies of things?  Might you have had a custom new definition of the command under 2013 that you became accustomed to, that is not loading in your newer version(s)?
Kent Cooper, AIA
