Anuncios
Objects out of syn when moved or stretched
No aplicable
When I copy objects or stretch them, then orbit round the model slightly to somewere else, when I come back to the objects I cannot select the moved or stretched objects as they are showing them in the original place but the graphics are correct. Regen works sometimes, or conversolid command but I cannot understand why this happens to the graphics....
Also when I stretch say a pipe in 3d, when I orbit around it it keeps jumping back to the original position until I let go of the orbit command
Anybody else have this problem
0 Me gusta
Responder
279 Vistas
1 Respuesta
Respuesta (1)
Alfred.NESWADBA
sounds that your displaylist was not updated with the new geometry.
Which version of AutoCAD are you using (command _ABOUT) and which graphic card and driver are you using (command _GRAPHICSCONFIG).
When you turn off hardware acceleration (command _GRAPHICSCONFIG) does the graphic then behave better?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
