Objects Not Showing Up in layout Base View
While modeling a steel mezzanine frame I decided it would be best to move the railing to it's own layer. After creating 'railing' layer and moving the railing solids to that layer, the layout base views will not show lines or hidden lines from the new layer. Can you help?
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
There are some known issues with the Viewbase command. I suggest that you try scaling the entire model by 1.0001 and then recreate the view. This usually will correct such behavior.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
