Objects disappear in viewport when selecting view from viewcube
We're having a bizarre issue with all our drawings lately. All of which started nearly at the beginning on June and has since affected all our working files (backups and all). The problem...
when we open a file as we last saved it, it looks as if all components/objects/layers are there and visible as before (01.jpg). we can turn on/off layers and rotate around with 3dorbit and everything is there (02.jpg; 01.jpg without pointcloud). Then if we choose a predefined view, either via viewcube or drop down everyting disappears from view (03.jpg) but it's still 'there'... doing a select all selects everything including the non-displaying objects.
anybody seen this before? we're at a loss of what to do as we're burning daylight on trying to figure it out.
it's an office wide issue...all systems have the following minimum specs and behaviors...
windows 10 x64
32gb+ ram
nvida geforce or quadro cards with latest drivers and 4gb+ ram
3.0ghz+ cpus
mix of ssd's and hdd's for os drives
files are either local or on networked file server (so location isn't the problem)
no files have xref's except for the pointclouds (which load fine initially)
drawings are at or very near zero
workspace layout is different as per user and all have same issue
affected layers are not frozen in NewVP properties
