Objects converted to blocks not showing when plot to pdf
hovalenict
hovalenict
Screenshot 2016-12-12 02.04.32.pngScreenshot 2016-12-12 02.05.22.pngScreenshot 2016-12-12 02.06.08.png
hovalenict
The different patterns in each area are BLOCKs. Meaning each areas' floor finish are converted to blocks(B ENTER) so that I can easily bring around each floor finish from each area which is convenient. But when I control P, set everything up and from plot style table, highlighted all color and chose Black color...
Then when the PDF file is out, the floor finishes aren't there, it seems that THEY are the only things not showing... Please help
imadHabash
I suggest to check the layer that the block at,if there is any Layer in your drawing that have unprinted layers  and relate to your block it will not appear when you plot.
AutoCAD create layer called Defpoints when DIM start to use,any objects on this layer will not appear.
Imad Habash
hovalenict
Thanks, imadhabashi! I am still new to this and embarrassed that I miss look 'that' lol...
