objects are dismissed when copying from file to another
nesmat.abdallah
nesmat.abdallah
when I try to copy objects from file to another they are copied in a mess way as shown in pictures .. why this could happened ?
file 1file 1file 2file 2
0 Me gusta
Responder
Soluciones aceptadas (1)
1.955 Vistas
8 Respuestas
Respuestas (8)
imadHabash
have you try Ctrl+Shift+V  for pasting , any changes ?
Imad Habash
pendean
Community Legend
Community Legend
Share with us your actual source and destination DWG files please.
rapidcad
@nesmat.abdallah , Usually problems are caused by block definitions being different in the two drawings you are copying between, but not like this - it appears there is some corruption in the data coming in which is indicated by some of your linework being stretched to different locations. Make sure that both drawings are using the same UCS, and rotation and if you are working in viewports try doing your copy from modelspace instead. If you used copy + paste I suggest you try wblocking and inserting instead. Otherwise run an audit on both drawings and choose the option to repair any problems you encounter and try again.
Let me know if any of these suggestions help.
ADN CAD Developer/Operator
nesmat.abdallah
it didn't work
0 Me gusta
nesmat.abdallah
sure
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
Thanks: in file #2 set both UCS and PLAN commands to WORLD and your problem goes away.
Basically, you lost track of your UCS orientation: the bigger problem is your flat 2-elevation is not flat and has many Z elevations and is totally out of whack. FLATTEN command doesn't seem to help much sadly.
Is this something you drafted/created in AutoCAD, or is it imported from another program or conversion?
nesmat.abdallah
thanks a lot it solved by the UCS order
the file is from the surveying company I have no informations about how it created
0 Me gusta
slavdimitrov1995
Community Visitor
Community Visitor
unfortunatelly changing the UCS and PLAN commands to "World" did not help when pasting the whole drawing from file "Plan 1" to file "Plan 2". Still many objects get dislocated.
Do you have any idea why is this so and how to solve it?
Thank you in advance!
0 Me gusta
