Anuncios
Object
Object
No aplicable
Hello All,
I would like to know why i can touch object on object window , however if i move on another working window i cant touch the object and then modify it.
How can i solve my problem ?
Sincerely,
Thomas
0 Me gusta
Responder
Soluciones aceptadas (1)
379 Vistas
5 Respuestas
Respuestas (5)
vinodkl
Sorry, your question seems to be confusing.
If I am not wrong are you talking about selecting the object first and then initiate a command is not working and you are required to select the object again. If that's the case type in the command "PICKFIRST" and set it to "1".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
No aplicable
no in fact i cant select any object and i dont know why
0 Me gusta
vinodkl
Can you post a snapshot or something, so that we know what problem you are exactly facing?
Can you type in the command "PICKADD" and set it to "2" and see if it makes it anything better.
0 Me gusta
No aplicable
for more details
0 Me gusta
vinodkl
Solución aceptada
I guess you are talking about the objects when in paperspace/layout. When in paperspace you need to double click to go into the modelspace or Type in the command "_.MS".
And you learn more about modelspace and paperspace/layout and how they work in AutoCAD.
0 Me gusta
