Object will not export; staying in two sections.
opesey
Message 1 of 10
opesey
Hello all,
I am having difficulty exporting a finalized part. I have checked all surfaces and components of the drawing that meet one another. I am getting two distinct groups when I got to unionize the part. Having these groups is a causing the part to be unable to export into an STL. Any help is appreciated and frankly, I have no idea how to fix it even if a solution is posted. Moving or resizing parts causes voids within the cylinders.
I have tried numerous times to redraw the part with all solid components but after unionizing the part, all components become hollow.
Any help is appreciated. At this point, I would really like to understand why, if we could hope in a discord or something while a fix is being made, I would love to understand what I am doing wrong for future parts. I can happily compensate for the time as well. Attached is the drawing.
Cheers!
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
@opesey In AutoCAD, exporting to STL requires all of your objrcts to be 100% 3DSolids or Watertight Meshes.
You have none at all and you got the same error message I did at the commandline, yes?
Message 3 of 10
opesey
Yes sir, same error message.
Message 4 of 10
opesey
Message 5 of 10
opesey
I will only respond to this thread to negate any confusion. I am not in any class, just doing this as a hobby.
When extruding, do I need to use a different command to make them all solids and not surfaces, that seems to be the underlying issue here with things not wanting to export.
Message 6 of 10
pendean
Community Legend
Community Legend
@opesey wrote:
...When extruding, do I need to use a different command...
Is this how you are doing it
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-B3B99AC4-B137-4144-A5ED-A8167906172D
That page has many links to additional instructions too.
Message 7 of 10
leeminardi
Your surface model has many holes that keep it from yielding a solid model via the surfsculpt command.  I capped some of the holes (red and green objects in the image below) but more needs to be done.
I think you should use extrude or sweep to create solids.  If the object outline object you use to extrude is a closed shape it can be used to create solids.
lee.minardi
Message 8 of 10
opesey
Yes, using that method. All parts remain solid until the union command, after that, it seems to hollow out most items.
Message 9 of 10
pendean
Community Legend
Community Legend
Union command? How was that used and on what?
Message 10 of 10
opesey
it was used on the whole drawing after i complete it, to essentially make the whole drawing "one piece"
