Object turn grey when erasing
No aplicable
When I am doing an erase and I do a selection window the objects I have selected turn grey.  This also occurs when I do a fillet, the lines that will no longer be existing turn grey.  Is there a way to turn off this feature.  I do not like it and I don't recall it being like that in the past.  Seems to have started in the last couple of days.  Running AutoCAD 2018.
0 Me gusta
Responder
Soluciones aceptadas (1)
984 Vistas
2 Respuestas
Respuestas (2)
J.FOCHT
Solución aceptada
Hello @Anonymous,
Try changing the option below:
Options  ->  Selection Tab  ->  Preview
Uncheck the "Command Preview" option.
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
jsiegel-vanderweil
Thanks!
Due to background glare, I could barely see the objects to erase once I selected them.
The potential for erasing the wrong thing was very strong...
AutoCAD user since 1988...
0 Me gusta
