Object Snap Overrule - no snap on locked Layers
Irreb
Irreb
Hi all,
I need an overrule that allows me to not snaps on object in a locked layer.
I researched through autodesk forums and i found this one:
https://forums.autodesk.com/t5/net/can-not-snap-locked-layers/td-p/3454804
but it is outdated.
Following the thread i came across this website that apparently have updated the override to Autocad 2018:
https://cadxp.com/topic/38718-d%C3%A9sactiver-les-accrochages-2-le-retour/
i am using Autocad 2022 now and i wonder if anyone knows how to make something similar that works on the latest version of Autocad.
tramber
I would prefer that we can decide that in the layers palette. That would be a terific idea, to me.
This last program by my friend (gile) would need an update.
PDFOSNAP to 0 and the replacement of your all set of locked layers by a PDF could help to do as if....
ВeekeeCZ
In my ideal world, there would be a sysvar
LOCKLAYER
0 current behavior, selectable and snappable
1 unselectable (default)
2 unsnappable
3 unselectable and unsnappable
In the Layer Properties Manager would be another column [Snap]
_gile
Update: LockOsnap.zip now contains an installer (LockOsnapSetup.msi) and works for all AutoCAD versions (vanilla and vertical) from 2013.
Do not forget to "unblock" the zip before extracting the installer.
Use at your own risks, deactivating osnaps may slow down AutoCAD performances.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Irreb
Great! i will try it soon, is this reversible? like, will i be able to toggle On and Off the osnap for locked layers whenever necessary?
Irreb
Installed the program it works great!
but given the big project size i'm working on it makes everything lag a lot!
I will definitely use it for smaller projects.
commands for locked layers:
LOKO -> activates it
LOKO (again) -> deactivates it
commands for xref:
XROS -> activates it
XROS (again) -> deactivates it
Irreb
Hi, does this work on autocad 2021 as well?
