- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Currently, I have two drawings open. In one drawing I can snap to the midpoint, endpoint, etc... of the viewport object in all paperspace tab's. yet in the other drawing I cannot.
The drawings were started from the same template.
The profiles used are exactly the same.
The viewports are on the "VPORT" layer in both drawings, and the layer is not locked.
All the properties of the viewports in the drawings match, with exception to exact center, size and shape.
OSMODE is set to 47 in both drawings and OSNAP is on.
I have no problem snapping to any other object in paperspace (or model) space in both drawings.
I have restarted my computer, restarted CAD, recovered both drawings, opened the drawings in two different CAD session and in the same CAD session in windows.
I have researched the knowledge base for this issue and have not found a solution.
Is there some property characteristic or SetVariable I am missing?
Any solutions OTHER than dumping the "broken" drawing or copying everything to a new drawing?
Mike
