Object enabler does not work for xrefs in parent drawing
Working with a survey file (let's call it "DWG A")which was created in Civil 3D and, using object enabler, am able to see all the contour lines in the file provided to me (I'm working in AutoCAD 2018). However, when I then insert as an xref into my parent drawing set ("DWG B"), I'm no longer able to see the contour lines of DWG A. It is as if object enabler is only working in certain files. Any ideas on where I'm going wrong? Seems like it's probably something simple...Thanks in advance.
