Object changes transparency after being moved
Message 1 of 21
I am trying to model a piping system where I am placing objects in different layers so that I can easily change their colours to make them stand out.  The problem I am having is part of the piping is fading out (figure 1).  When I move it out side the tank it returns to normal (figure 2).  The weird part is that the same pipes on the other side of the tank are not doing that (figure 4) which are an exact copy (and mirror).
I tried redoing, but the same results.  The objects are not interfering with any other objects.  I do not understand.
There is another set of pipes that are doing the same thing as well as box that I am using to represent a sheet of metal.
Any ideas?
Replies (20)
Message 2 of 21
john.vellek
Hi lukestephen.e,
Welcome to the Autodesk Community!
Is it possible to attach a sample drawing that exhibits this problem? I would like to duplicate the issue with the transparency values.
John Vellek
Message 3 of 21
TheCADnoob
to me it looks like the objects are behind the other objects where the others are not. can you verify from a different angle that the geometry is indeed symmetric?
CADnoob
Message 4 of 21
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Use a visual style like "realistic" or "conceptual", your's seem to be set to "x-ray".
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 21
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 6 of 21
Here is a sample of the file.  Sorry about the late reply I was away from my computer for the weekend.  As you will see there are 2 pipes on each side that do this.  I don't understand why.  When I saved it as a new file, all of the pipes that are inside the tank started doing the same thing, where they are faded out.
Also, yes I am in X-RAY because there are pipes elsewhere (which again, are now doing the same thing) that I need to be able to see, but they are behind the tank wall.
Message 7 of 21
TheCADnoob
CADnoob no prob.pngIm not seeing the same behavior on my end..
is it perhaps that you have the item(s) selected and the highlight is causing it to look the way it does?
CADnoob
Message 8 of 21
I don't think so.  I made sure that I had nothing selected.  Even tried selecting something else and then un-selecting it to make sure nothing was selected.  Did you try moving it?
Message 9 of 21
TheCADnoob
moving it did not recreate the problem here..
CADnoob
Message 10 of 21
May I send you the rest of the drawing?  There is another pipe that it does it a bit more consistently on.  I have tried googling transparencies and such, but nothing so far.
Message 11 of 21
Alfred.NESWADBA
from first post:
From your last post
Visual style "X-Ray" has it's type of transparency by itself, so whenever one object is behind another one it will be displayed like faded.
So my question now is: what is the difference between what you are seeing as "faded out" but unusual to the visual style.
For me the screenshot 1.PNG looks normal for this type of visual style.
In case it's a display issue you always can check to disable the hardware acceleration and see if that makes something better.
- alfred -
Alfred NESWADBA
Message 12 of 21
TheCADnoob
Fire away
CADnoob
Message 13 of 21
The way it is fading out the pipes is different then how it changes other pipes to show that they are behind another object.  I changed the view around and this it does faded them out when the are behind the tank wall, but it is in addition to this other fade, making them rather difficult to see.
Attached bellow is the file with the rest of the pipes in it.  On my computer it is consistently showing the very bottom pipe with the part that is inside the tank as faded and the part that is outside as unfaded, while most of the other pipes in the tank are not faded at all.
At first I thought that this might have something to do with it cutting though the sides of the tank, but I double checked and the red pipes never actually touch anything else at all.  So I don't think that that is what is causing the problem.  Also with the red pipes try moving them and then moving them back (or ctrl-z).
Thanks so much for all of your efforts in trying to help!
Message 14 of 21
john.vellek
Hi @Anonymous,
I am at a loss as I too can not reproduce this.
Purge did remove some zero-length objects but Audit found on problems.
Does this still show up in a viewport?
What happens if you adjust draworder or copy past your model into a new drawing?
John Vellek
Message 15 of 21
Tried the above suggestions.  Unfortunately none of them worked for me.  I tried purge, viewports, drawing order (all of them), and copying to a new drawing.
In layouts I used the realistic view for the top red pipes and was able to make a cut, then blown-up detailed drawing (1:50), for the bottom, making x-ray unnecessary.  But the drawing came out very pixelated.
Since you guys can't seam to duplicate the problem on your computers, that might mean that no one else in the office will have the problem either.  I will test it on a coworker's computer to see if the problem still persists.
Edited by request
Discussion_Admin
Message 16 of 21
TheCADnoob
The new file behaves for me as well..
Is your CAD older than 2015?
CADnoob
Message 17 of 21
I am using AutoCAD 2014
Message 18 of 21
TheCADnoob
I have read a post once and there were some issues which caused 3D solids to not display correctly in things before 2015. It didn't manifest like your problem but for shot in the dark you can try it.
The solution was to open the drawing in 2015 and save it. This forced the object to be re-created. Do you have access to a 2015 install?
I would offer to save the file for you but the current machine i have access to has a student version installed and that would change your file to a student file which is undesirable.
CADnoob
Message 19 of 21
No I do not have access to one.  Most people at work are using 2014 or earlier.  Thanks for the offer though!  And thanks again so much for everyone's efforts.
Edited by request
Discussion_Admin
Message 20 of 21
OK.  I tried on a few other machines.  Those that also had CAD 2014 also showed the same problem, but those with 2013 did not have that problem.  Thanks so much for all of your help!
