Object area field in mtext not updating with regen, regenall
in the screencast, I've made a rectangle with mtext containing field (area of rectangle). Is it normal that the only way the field updates is if I click into the mtext and right click the field and select Update Field? I've tried using regen, regenall, and changing fieldeval sys variable to no evail. Is there a way to make the mtext field auto update?
rkmcswain
What is FIELDEVAL set to? 31?
Unless I missed it, I didn't see you check this in the screencast.
I didn't check it in the cast but I did check it. Initially set to 31. I tried 0,1,2,4,8,16 with no difference
cadffm
31 is default and well.
2018 is updated? 2018.1.2 is current, check this in your Command: About Dialog
Sebastian
Since this is a license supplied by my employer, I'm not sure I can update.
pendean
Community Legend
Community Legend
You need the update.
